Hello, I am new to this board and have a few questions.
First off I would like to say I have read all of the many posts on blinker problems and tried many of the suggestions with no success.
the car: 1972 240 z
The problem: Right rear turn signal doesnt work. I can get a test light to light occasionally at the taillight harness, but it is much dimmer than at the left. I have tried cleaning both the turn signal switch and the hazard switch. I have also replaced both of their flashers (relays). I have current at the hazard swith and the blinker switch.
What are the 2 plugs that go through the floor at the rear of the car near the taillight panel? one has 1 wire , and the other has 2 wires. I ask this because when I put my test light into the plug with 2 wires it rapidly flashes, at a rate different than the hazards or blinker. I t does this flashing even when both hazard and blinker switches are off.
I belive this is a ground problem, a but I am unsure where the ground to the rear blinkers is located.
Thanks, any and all advice is appreciated.
Cory Thompson
https://www.classiczcars.com/topic/11030-need-blinker-help/
1. Clean the connectors
2. Clean the connectors
3. Check voltages along the way & clean again. Look for broken wires & such.
Don't forget to clean the cennectors at the tail light harness and the sockets themselves. Make sure the bulb is a good one.
Whatever it is, it's something simple. You'll :stupid: yourself later.
https://www.classiczcars.com/topic/11030-need-blinker-help/#findComment-75086
I have a "buzzer probe" for such occasions. Instead of buying new bulbs and things, you just hook up the buzzer, especially, if you are working alone.
Just a cheapo buzzer from Radio shack, glue it to a tongue depressor/stick. One wire with alligator clip for ground and one with with a pin/nail for probing.
Really helped when I was fixing the horns!! LOL
https://www.classiczcars.com/topic/11030-need-blinker-help/#findComment-75147
  • Who's Online   0 Members, 0 Anonymous, 1,435 Guests (See full list)
