According the my Haynes manual, these are the smog things on the L28 (auto trans) and I would probablly do these things with them:
BCDD-- disconnect vac line/adjust
EGR Control Valve-- Remove, cover hole
Thermal Vacuum Valve-- remove, plug
Backpressure transducer valve-- remove, plug holes
Vacuum Delay Valve-- remove, plug holes
Altitude Switch-- remove & bypass
Vacuum Switching Valve-- disconnect from dizzy
Dashpot-- ?
any suggestions?
thx
https://www.classiczcars.com/topic/11035-desmogging-280z-attack-plan/
I'd have to agree with ZmeFly. Each one of the things you mention have a negative effect on the cars performance when non-functional. Some more than others. So, if you remove them all, what do you intend to do to compensate? The troubleshooting charts would be useless since many performance problems can be traced to malfunctions of these devices.
The idea was to clean up the engine. All that's left would be the intake, headers, dizzy, and injectors/ injector rail.
At the least I would like to remove the EGR valve.
I suppose I could do one at a time, and see if it's good or bad, then replace it .
Well, it runs and I got more important fixes like the headlights. That's why I do the reasearch & keep notes,
thx
  • 1 year later...
If you plan on removing the egr valve, you'll also have to plug the hole in the exhaust manifold.
Also, I've been trying to figure out how to clean up my engine too, so here's one thing I found out: The breather hose from the valve cover runs to the boot after the mass air sensor (at least in CA). There's a vacuum in that line sucking into the boot, away from the valve cover. You'll need to put some sort of catch or tube or filter on the end of the valve cover to allow it to breath, but if you plug the hole in the boot, you should be good. That's step one in theory, and pretty simple to replace if you have to go back.
  • Who's Online   1 Member, 0 Anonymous, 1,493 Guests (See full list)
