Posted April 4, 200421 yr comment_75495 I went to the dyno yesterday and I'm a bit disappointed in the result. my first run was at the stock setting psi and got 190 wrhp, AF was very good so i took it up to 10pis and got 198wrhp and AF mixture still but when i tried to go 12 psi it started to ping and the guy had to back off, then i was like try 15 psi,( 15psi is where i would like to run) so he get on it and if start to ping so he get off again this time we make 215 wrhp but only got the RPM up to 5500. I had them stop and left on the way I had the boost set at 12psi I tried to run at 12 psi and it ping so I pulled over to check things out and found that the distributor was advanced as fas is it could go so I turned it back half between full retard and adv. got back in the car and now I can boost 12psi all day. I want to go back to the dyno and see if this makes a difference but before I go I would like to know what you guys think could this have been my problem, the guy at the dyno shop told me I need more fuel as I ran lean on the last two runs, I just wonder if my lean condition was caused my timing being so far advanced. MY set up 71 240z 83 turbo set stock management system 89 supra intercooler turbo x blowoff valvemanual boost controllerLSD3" EXT. part press bend and part mandrel3" mufflercustom 2 "1/2 down pipe from Scottie gcold air intakeplug stock pop valve opening93 octane gas Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/ Share on other sites More sharing options...
April 4, 200421 yr comment_75501 Is this an L28?steve Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/#findComment-75501 Share on other sites More sharing options...
April 4, 200421 yr Author comment_75504 yes it's a l28et Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/#findComment-75504 Share on other sites More sharing options...
April 5, 200421 yr comment_75545 Are you running the stock FI computer? If so get a tunable aftermarket computer. Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/#findComment-75545 Share on other sites More sharing options...
April 9, 200421 yr comment_76148 did you do any better? i am about to do the same to my 71. what kind of numbers were you hoping for? are you going to get an after market management system. how much would that go for? Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/#findComment-76148 Share on other sites More sharing options...
July 1, 200817 yr comment_252532 Is it possible you knocked some carbon out of your cylinder dropping your compression ratio down? Just thinking if you've never had the engine apart, I know running on differnet fuels can do that sometimes too. (alcohol etc). Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/#findComment-252532 Share on other sites More sharing options...
July 1, 200817 yr comment_252533 Is it possible you knocked some carbon out of your cylinder dropping your compression ratio down? Just thinking if you've never had the engine apart, I know running on differnet fuels can do that sometimes too. (alcohol etc). I wonder if maybe he figured out his problem in the last 4 years since this post was originally made... Link to comment https://www.classiczcars.com/forums/topic/11094-disappointing-dyno-result/#findComment-252533 Share on other sites More sharing options...
