Hey guys,
I just got the brake booster off my parts car at the ranch. I think the diaphram on mine is leeking so I am going to replace it tommorow. Funny thing, my friend took the master cylinder off while unbolted the booster from the inside of the firewall. So I did not see exactly how it went together... I think I can figure it out but want to know if I should empty the master cylinder of brake fluid before I go at it... Or any other tips...
Thanks
https://www.classiczcars.com/topic/11187-brake-booster/
I have seen this said a few times, could possibly be your problem?
"IMPORTANT: When removing the brake booster, or installing a used one, it is critical that you do not pull out the engine-bay side pushrod of the brake booster. The so-called "reaction disc", which is a solid rubber disc about the diameter of a quarter, can fall off inside the booster. The result will very poor brake feel - you will have a deep spongy pedal and then all of the sudden you will get full braking and the car will stand on its nose."
https://www.classiczcars.com/topic/11187-brake-booster/#findComment-76439
yep,
pulled that out... It was suprisingly unattached also... I thought it might be broken it just slipped out so easy...
but I dotn know if the thing fell.. I only got to drive it for about 5 minutes before I had to entertain the girlfriend :cheeky:.
Anyway to fix it?
https://www.classiczcars.com/topic/11187-brake-booster/#findComment-76591
  • Who's Online   1 Member, 0 Anonymous, 1,354 Guests (See full list)
