surfsnake2 Posted April 14, 2004 Share #1 Posted April 14, 2004 the front left tie rod on my 260z is rusted over according to les schwab an it can not be alligned they said the tie rods need to be replace, so i guess i need to know how to remove and replace a tie rod fairly close to step by step if possible thanks Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/ Share on other sites More sharing options...
z_boi Posted April 14, 2004 Share #2 Posted April 14, 2004 get a tie rod puller. remover the cotter pin and nut from the tie rod that holds it to the steering knucle. Then with the tie rod puller, put tension on the tie rod, take a hammer, and hit the knucle with it a few times, put more tension on the tie rod end, then wack it a few more times, and repeat that till it pops out. thats to remove it. to put it bak, jus simply tighten it till it seats and the nut line up wit the hole for the cotter pin. dont back it off if the pin doesnt go in. either try to tighten it a bit more to make it reach or back it all the way off then tighten it up again till it lines up.Oh yeah! and when u put the tie rod end back onto the rack. make sure u try to get it as close to where it originally was other wise ur alignment is gonna be really screwed up. since ur takin it to get allinged n e how, it doesnt have to be exactly.Hope this helps and not confusing u. Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77014 Share on other sites More sharing options...
surfsnake2 Posted April 14, 2004 Author Share #3 Posted April 14, 2004 first off what is a tie rod puller, and what might it look like and where do i get it does it look like some kind of fork thing? and how do i use the tie rod puller to put tension on the tie rod.oh and how long can i expect this to take Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77092 Share on other sites More sharing options...
St.stephen Posted April 14, 2004 Share #4 Posted April 14, 2004 its generally referred to as a "pickle fork". It basically looks like a tuning fork. you would put the pickle fork in between the tie rod end and steering knuckle and hit the end of the pickle fork until the end drops out. should only take a couple of good whacks with a heavy hammer. once you drop the tie rod out of the knuckle and begin unscrewing the tie rod end from the steering rack, it helps to keep track and count the number of turns to ensure a relative close match on the reinstall. Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77094 Share on other sites More sharing options...
beandip Posted April 14, 2004 Share #5 Posted April 14, 2004 If you live near a Harbor Fright they have peckle forks for less than $6.00. Check with midwesz.com for the new tie rods . they are a sponser here and give us a good price on parts. Gary Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77118 Share on other sites More sharing options...
surfsnake2 Posted April 14, 2004 Author Share #6 Posted April 14, 2004 is this a day long job or how many hours might i be looking at?ok and i just want to when i went by les schwab this is the quote i gotit says 2 ES2277L TIE ROD END @ $40.30 a piece so $80.60 total2 TIEROD ENDS/RACK AND PINION INSTALLATION @ $64.75 a piece so a total of $129.501 ES2109R TIE ROD END @ $40.861 ES2110L TIE ROD END @ $40.96So is that for all four tie rods? or is that just the front, what exactly do i need to purchase to replace just the front two that are rusted? and do i need the 2 TIEROD ENDS/RACK AND PINION INSTALLATION ? and where is the best place to get themThanksbtw i could not find the tie rods and midwestz.com if they are there could i get a direct link? Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77127 Share on other sites More sharing options...
St.stephen Posted April 14, 2004 Share #7 Posted April 14, 2004 its only a couple of hours. my post may be too late however 1. jack up the car, place jack stand under front mount2. Remove front tire3. remove cotter pin in castlelated nut on tie rod 4. insert pickle fork between tie rod and steering knuckle5. hit back of pickle fork forcing in between spindle and tie rod6. tie rod will pop out. 7. you'll need to loosen the tie rod from the steering rack. may help to spray with penetrating fluid. 8. installation is the reverse of this process. hope this helps :classic: Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77134 Share on other sites More sharing options...
LanceM Posted April 14, 2004 Share #8 Posted April 14, 2004 It shouldn't take long to do, couple of hours at the most, probably more like an hour. There are only 2 tie rod ends on a Z.www.rockauto.com has them for $22 each, I've bought a lot of parts from them and they ship quick. Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77165 Share on other sites More sharing options...
surfsnake2 Posted April 15, 2004 Author Share #9 Posted April 15, 2004 i thought there was an inner and outer tie rod on the front and what about the rack and pinion so this is the left (outer) tie rod that i assume i am needing to replace in this image...right? sorry its so big Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77194 Share on other sites More sharing options...
St.stephen Posted April 15, 2004 Share #10 Posted April 15, 2004 yes that is what needs to be replaced. Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77284 Share on other sites More sharing options...
ChrisA Posted April 15, 2004 Share #11 Posted April 15, 2004 There is a joint inside the boot in the picture you posted. It's up to you to determine if it need replaced or not. If the boot isn't torn more than likely it's okay unless you have really high mileage and are concerned about wear. You can test for play(looseness) in that joint to see if its bad. Chris Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77290 Share on other sites More sharing options...
surfsnake2 Posted April 16, 2004 Author Share #12 Posted April 16, 2004 so do i need the rack and pinion set thing? Link to comment https://www.classiczcars.com/topic/11254-tie-rod-removal-installation/#findComment-77332 Share on other sites More sharing options...
