Ernest Creamer Posted March 23, 2001 Share #1 Posted March 23, 2001 Several years ago I had a catalog from a company called "Longs Z Parts". I have lost the catalog and was hoping that someone might have the addy so I can contact them for a new catalog. If not, maybe someone could tell me where I can get gaskets for my '71 240 Z. Thanks Ernie Link to comment https://www.classiczcars.com/topic/115-rubber-gaskets-for-door-hatchback/ Share on other sites More sharing options...
JULVEN Posted March 24, 2001 Share #2 Posted March 24, 2001 Just go to the link part of this web site and go to the parts section and select the Vitoria British one. This is the mother company of Longs.------------------JB5/70 240Z Link to comment https://www.classiczcars.com/topic/115-rubber-gaskets-for-door-hatchback/#findComment-268 Share on other sites More sharing options...
Ernest Creamer Posted March 24, 2001 Author Share #3 Posted March 24, 2001 Thank you , I appreciate the information. Link to comment https://www.classiczcars.com/topic/115-rubber-gaskets-for-door-hatchback/#findComment-269 Share on other sites More sharing options...
norcal z Posted March 24, 2001 Share #4 Posted March 24, 2001 Not to knock VB, but there are a couple of other sources you should also check outfirst, before buying anything: Motorsport Auto www.zcarparts.com, and Courtesy Nissan http://www.courtesy-nissan.com/------------------Gary P'72 240z - 5 spd., Crane Cams elec. ignition mod, BFG Comp TAs (needs tlc)'97 JGC Laredo - K&N filter mod, Don-A-Vee TB spacer, factory skids/front tow hooks, Con-Ferr roof rack Link to comment https://www.classiczcars.com/topic/115-rubber-gaskets-for-door-hatchback/#findComment-270 Share on other sites More sharing options...
gschne Posted March 29, 2001 Share #5 Posted March 29, 2001 Aother place to check out is Banzai Motorworks. Mike McGinnis is very knowledgable and has rubber goods not currently available from dealers. His web page is www.zzxdatsun.com. Tell him "Galen" sent you. Link to comment https://www.classiczcars.com/topic/115-rubber-gaskets-for-door-hatchback/#findComment-832 Share on other sites More sharing options...
