Site Updates this Weekend ×
Check your local "u-pullits", ebay, etc. Try to get a whole car- you want to get everything wired or bolted to the engine-and the pieces at the other end of the wires! I bought a complete turbo car off Ebay last year for $351, and sold almost $500 in parts off of it.
or go to:
www.car-parts.com
1982
nissan
280zx
engine
w/turbo
I found approx 100 L28et s ranging from $850 to $175 If you go this route, you MUST call the yard and see if they have the wiring harness and ecm, or just the engine-most will have only the engine assembly-those pieces that are on the engine side of the manifolds-9 times out of 10 the Turbo is gone!
Good luck!
Will
Yeah they are hard to come by these days. I've been to the junkyards a few times this month and all I see is non-turbo 280zx's. A full service salvage yard should have one tho. Expect to pay more however.
Otherwise you can cobble together the parts and add them on to your current motor. The only problem there is the fuel management system. That can get pricey.
ebaymotors.com be a fanatic
  • Who's Online   1 Member, 0 Anonymous, 1,073 Guests (See full list)
