tanny Posted May 2, 2004 Share #1 Posted May 2, 2004 I am sticking a 1980 280zx 5 speed into my 1973 240z and was wondering if I will need to modify the shifter. I think I've read most of the posts but am still a bit confused. Some threads say great fit, others say you need to do some bending. If bending is needed, does someone have a pattern to use? I thought I saw something about that a while ago, but can't seem to find the info. Thanks, Victor. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/ Share on other sites More sharing options...
sblake01 Posted May 2, 2004 Share #2 Posted May 2, 2004 My car has a 82 Maxima 5 speed. It went in with no problem but I did use the shifter from my 78 5 speed. I'm not sure if that applies to your 73. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79287 Share on other sites More sharing options...
LanceM Posted May 2, 2004 Share #3 Posted May 2, 2004 I put a 81ZX 5 speed in my 73 no problem. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79288 Share on other sites More sharing options...
240ZX Posted May 3, 2004 Share #4 Posted May 3, 2004 I put a late model 5 speed (shorter in length than original 4 spd)in my 1970 and it required trimming a little off the front of the tunnel opening, in addition to a modified shifter. This may be specific to the very early 240s as it seems the later 240s do not have the same clearance problem. I'm not sure now accurite this info is but I did have to mod my tunnel and shifter for a proper install. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79417 Share on other sites More sharing options...
Victor Laury Posted May 3, 2004 Share #5 Posted May 3, 2004 This may be specific to the very early 240s as it seems the later 240s do not have the same clearance problem. You are correct, Sir Tom.Victor, You will have no problem installing any FS5C71B transmission from a 78 280Z, 810, 79 ~ 83 280ZX, except for those 280ZX Turbo models, fitted with the Borg Warner licensed T-5 transmissions. It is the T-5 unit that requires modifications to the shifter and driveshaft.Here's my write-up of my install of a 1980 ZX 5 speed into my 72.Vic's 5 Speed Adventure Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79420 Share on other sites More sharing options...
240ZX Posted May 3, 2004 Share #6 Posted May 3, 2004 Hey Victor,You can imagine I was confussed, at first, when I installed my late model 5 spd, because every article I read said........"They just bolt right in without any mods!!!". Can you see me saying....Yah right!!? Of course later on I discovered that the later 240s did not require the mods. Live and learn! Anyway, with the 5 spd, 3.90 diff, and my 235-40x17s my Z accelorates very nicely concidering my L6 (2.8 litre) is internally stock. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79424 Share on other sites More sharing options...
tanny Posted May 4, 2004 Author Share #7 Posted May 4, 2004 Thanks everybody. Sounds like there should be no mods necessary with my installation. Excellent! Now I'll keep my fingers crossed that the tranny will at least shift into all 5 gears. I will put in new front, rear, and front plate seals, along with new shifter bushings and new speedo pinion o-rings before I install the 5 speed. Victor. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79515 Share on other sites More sharing options...
Darrel Posted May 4, 2004 Share #8 Posted May 4, 2004 If you can find a 5 spd shifter from a 280 get it. The length of the pivot point to the bottom of the shifter ball is shorter on the 5 speed. And to keep the shifting smooth, get the "help" part number 38377 to replace the bushings. They are for a chrysler door hinge but works perfectly for our cars. Link to comment https://www.classiczcars.com/topic/11532-transmission-shifter-4-to-5-speed-swap/#findComment-79638 Share on other sites More sharing options...
