The front grill mounting points for the S30 changed some time between the 72 and 73 models.
The 73 is more like the 260z s30 than the 240z s30 in some regards. Another difference that the 73 has in common with the 260z is the lip on top of the radiator panel that follows the contour of the bonet.
The 73 grill should fit on later model S30's (260z). Not sure about late S30 models though (280z).
Also the pictured grills ar the export market grill. The domestic market fairlady Z got the mesh grill (with the Big mesh), and the 432 got the fine mesh grill.
