The car did not over heat at all - I took a preventative measure in replacing it. I actually don't see how it didn't overheat - the old radiator had large holes all the way through it! I tried replacing the vacuum lines today - it seemed to help a little, they probably needed replacing anyway. I also messed with the idle control...but to no avail. I am going to try redoing the timing tomorrow and see if that helps or fixes it. It seems like maybe the fuek/air mixture might have too much fuel in it too. I keep going back trying to figure out what I could have knocked when putting in the radiator but I just can't figure it out. But hey, thanks for all the input!
Hi
Is your car manual or automatic , if automatic the smoke can be transmission fluid comming from a bad vacummodulator valve .
,pull of the line giong to the valve ,cover the vacum hole in to the intake manifold and see if the smoke stops .
Zafer
  • Who's Online   2 Members, 0 Anonymous, 1,109 Guests (See full list)
