Guest 260zRagTop Posted May 8, 2004 Share #1 Posted May 8, 2004 fuse box fuse look good?? also the battery is loosing power.any ideas.1974 260z Link to comment https://www.classiczcars.com/topic/11619-help-all-electric-gauges-stopped-working/ Share on other sites More sharing options...
Bambikiller240 Posted May 8, 2004 Share #2 Posted May 8, 2004 You cannot tell if fuses are good by looking at them. You need to remove them all and test with an ohmmeter. Have your battery and alt checked checked by auto repair shop or parts store. Many will do this for free. Link to comment https://www.classiczcars.com/topic/11619-help-all-electric-gauges-stopped-working/#findComment-80171 Share on other sites More sharing options...
44014 Posted May 9, 2004 Share #3 Posted May 9, 2004 yeah sounds like your tacho fuse has blown like half your gauges run off this one fuse you can check them in there just get a multi meter put the earth on the body some where and if you get 12 volts on one side and not the other it is blown note:the accesory you are tesing has to be on good luck man Link to comment https://www.classiczcars.com/topic/11619-help-all-electric-gauges-stopped-working/#findComment-80271 Share on other sites More sharing options...
