Hah, i know black is ground. Well, i plugged it in finally and it doesent want to work. I dont have any speaker wires connected, only red and yellow (power). And no response. Well, the sony radio had no response either before.....i really hope my electrical system isnt ****ed. Any Ideas?
Im pretty sure yellow should go to your battery for permanent power while the red one should go to accessories power, which is only high when the key is turn past acc.
It could be the other way around, my mind is a blank at the moment.
Either way you could connect them both to 12V for testing purposes to see if the deck turns on, the only downfall of leaving it like this is the deck could be left unning while the car is off leaving one flat battery.
there are 2 manuals, user manual and installation manual.
But like I said before, one will go to the battery and one will go to and acc. powered line.
More than likely the fused one will go to the battery, and like i said also, if you put them both to 12V the unit WILL work for testing purposes.
I know, the yellow one goes to the battery but i am still learning with electrics, so i really dont know THAT much. I just thought that ,since the end of the wire has a metal end for plugging into somthing, their was somthing i just plug it into. The red one is plugged in just fine, well im just waiting for my 280z haynes manual, maybe that will help.
  • Who's Online   0 Members, 0 Anonymous, 1,410 Guests (See full list)
