O2 sensor and fuel pump connection?
I've had a ongoing promlem with my 83 280 turbo. Driving along at "noload" power the fuel would cut out, if you stepped on the gas it would cough and accelerate properly. I took it to the dealer and after replacing all the sensors he said it was the brain. So I bit the bullet and replaces the computer. And no it wasn't the brain - it still did it.
So I stuck it in storage to work on it later, but two years later I had to move it 10 miles to a new storage site. This time although it started and ran fine when I went to drive it any time I got over 1000 rpm it cut out. anyway I put it away for another 3 years then started it and moved it into the shop.
The only sensor that was not replaced with a new unit was the O2 unit so I purchased and installed a new unit. Now my fuel pump will not work
Is there a loop in the computer program between these two components? or did two things happen to fail at the same time?
Any suggestions would be helpful before I start my journey down the replace and spend road.
Thanks,
Kysa
https://www.classiczcars.com/topic/11748-o2-sensor-and-fuel-pump-connection/
when i first got my 78, i had to fix a few wiring problems, but the fuel pump still wouldnt run until i unplugged the oil pressure sending unit. try unplugging that and see if you get the fuel pump to run. it has something to do with a safty feature so that if your oil pressure goes below a certain point, it will shut off the fuel pump saving the enging from any damage, but have had nothing but problems with mine. LOL.
