I have searched the forum for info on this, but could not find it.
I have the steel mag wheels for my 240, and they have gotten real dirty over time.
I was wondering what you guys have used to polish them up or clean them?
I wish to restore them to look new without making a whole day of it.
Is there a mag/wheel cleaner that you would recommend
Thanks for any help you can give.
-Marc.
https://www.classiczcars.com/topic/11794-wheel-advice-please/
with hub caps?
If so, the best route to take would be to get a drill with a wire brush and grind off all the paint and rust or corrision that is on the wheel itself.
Then, try as best you can to match the original color and repaint.
Now if it is an aluminum wheel I would sand, steel wool and then polish.
Marc.
If you mean the five-slots that are on the red Z in your gallery, they are aluminum not steel. In which case use an aluminum polish like Mother's, Blue Magic, etc. They're all pretty much the same chemicals. The rims pictured aren't as intricate as some others so they won't be as hard to polish. The more you buff them, the shinier they'll get. I actually like the results of hand buffing. I used my bench grinder with a buffing wheel (and many hours of work!) to polish a set of 'Iron Cross' ZX wheels to look like chrome. When I put them on my Z, I just didn't like the look. The hand polished look is more of a satin type shine which I feel suits the early Z better. Take a look at Victor Laury's car. Just my opinion.
