flyer4100 Posted May 22, 2004 Share #1 Posted May 22, 2004 Just removed the fuel tank from my '74 260Z and suprised by what I see. I was always led to believe reading through this and other "Z" forums that the 260Z had an electric fuel pump at the rear. In addition having read the FSM for the 260Z it quite clearly shows a "Fuel Liquid separator" and additional plumbing of 2 ventilation hoses, none of which are fitted to my car. Anyone got any ideas about this tank ?? is it off a 240Z ?? Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/ Share on other sites More sharing options...
260DET Posted May 22, 2004 Share #2 Posted May 22, 2004 What month/year is it? There is a period of crossover time during which 240 bodies were fitted with 260 engines and called 260's. Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82249 Share on other sites More sharing options...
flyer4100 Posted May 22, 2004 Author Share #3 Posted May 22, 2004 Well the compliance plate shows 5/74 and the VIN number is RS30-000874 Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82251 Share on other sites More sharing options...
Bambikiller240 Posted May 22, 2004 Share #4 Posted May 22, 2004 Looks like a normal fuel tank for either a 240, or early 260Z. Just to be sure, you do realize that the electric fuel pump would be external to the tank, and not located interally. Right?Attached is is a picture of the fuel pump we (USA) received on 73 to 74 Z cars. I expect it would be the same one fitted to Aussie Z's. Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82252 Share on other sites More sharing options...
Mr Camouflage Posted May 22, 2004 Share #5 Posted May 22, 2004 The electric Fuel pumps were exteranl to the tank. It's very possible that a PO could have removed it. They humg off a bracket that was bolted to the chassis cross member under the boot floor panel. Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82257 Share on other sites More sharing options...
flyer4100 Posted May 22, 2004 Author Share #6 Posted May 22, 2004 thanks for the pics...but sadly no evidence that they it was ever there. I also cannot find any find any spare wires for the elctrival supply. The wiring loom to the sender unit just has 2 wires, no spares or remains of other wiring.......... Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82259 Share on other sites More sharing options...
Murph Posted May 22, 2004 Share #7 Posted May 22, 2004 I have a 4/74 260Z and I've been through the same thing. What I found out was that the early 260's didn't have the electric pump, although they do have the wiring for it. As for the "Fuel Liquid separator"/expansion tank and additional pumbing....the aussie zeds didn't get it. So, your setup there is quite normal. Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82305 Share on other sites More sharing options...
flyer4100 Posted May 22, 2004 Author Share #8 Posted May 22, 2004 So where would the wiring for the pump be routed - the fuel sender wiring comes from the rear of the boot area r/h side Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82309 Share on other sites More sharing options...
Murph Posted May 23, 2004 Share #9 Posted May 23, 2004 Yep, that's where it comes out. The green wire that connects to nothing is the pump +ve. Just ground the pumps -ve to the chassis.Now, from what I've found with my car, there's a pretty big voltage drop between the battery and this wire (~2V with no load). Add that this wire is unfused, old, and really wont be able to push a decent current. So I'd strongly recommend if you're installing a decent electric pump, to run a dedicated, relayed and fused feed straight from the battery.Also, power to that wire comes on with the ignition. You'd be better off having it attached to a oil pressure switch. That way in the event you had a crash, the pump will stop when the engine does, minimising the risk of your pump pushing 500HP worth of fuel onto the ground. Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82314 Share on other sites More sharing options...
flyer4100 Posted May 23, 2004 Author Share #10 Posted May 23, 2004 Bingo.........found the wires a green and a black. Seems the PO must have opened up the insulation about 3 inches back and put some more tape back on .....The car is going to have a complete wiring overhaul anyway but at least I know it was there to start withCheers everyone for their help on this Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82332 Share on other sites More sharing options...
EScanlon Posted May 23, 2004 Share #11 Posted May 23, 2004 The wiring being a few inches away from the sender is normal. That's how Datsun would "park" the wires they weren't going to use. Check the front and you'll find that the Fog Lamp wiring is also there but more than likely taped off also.Your tank is also missing the two vent tubes that lead to the fuel vapor expansion tank. Those two vents would be located, one above the sender and one to the far back and far right of the tank in the picture.Enrique Scanlon Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82338 Share on other sites More sharing options...
Rogersz Posted May 23, 2004 Share #12 Posted May 23, 2004 My 260Z has exactly the same tank and no pump , RS30-0006464/74 . i cant work out why the outlet for the breather tube pointsaway from the filler neck? Link to comment https://www.classiczcars.com/topic/11839-fuel-tank/#findComment-82346 Share on other sites More sharing options...
