Don't know the answer to your question Steve but its a good point, with two people aboard and a full petrol tank it would likely be signficantly bum heavy. I used to assume that putting the battery etc in the back was a good thing but this is not necessarily so.
https://www.classiczcars.com/topic/11982-240z-weight/#findComment-83377
To my knowledge it wasn't remounted. I've never seen the battery position changed in a rally zed.
Perhaps if the zed had a separate boot compartment it might have been a different story. Even so the zed was a heavy beast in comparison to other rally cars of it's era.
I remember reading somewhere that the distribution was 55-45, which is regarded as pretty good for something that isn't mid-mounted!
https://www.classiczcars.com/topic/11982-240z-weight/#findComment-83379
Steve , it's been 3 or 4 years back but I weighed my '73 with me 215 lb driver and a half tank of fuel , total it was right at 2600 lbs and about evenly split , the front was about 100 lbs more than the rear. I am sorry I dident write the numbers down. Hope this helps. Gary:classic:
https://www.classiczcars.com/topic/11982-240z-weight/#findComment-83799
  • 4 weeks later...
All works rally Z's were known to be front heavy and it took a good driver to get the back out on a stage. Mehta wrecked rather a lot of them; no doubt because of the understeer.
As to weight balance and ratio's Big Sam, which is now a lightweight racer, weighs 912 kgs (2010lbs) and the balance is 49.5:50.5% (back to front). Even though it is an ex works car and has a heavily reinforced shell and Sam's engine is further back than norml, together with the fibreglass front wings I am surprised to see some of the ratios quoted here.
We always set up Sam on 4 corner weight guages connected to a pc.
Regards
Nick Howell
https://www.classiczcars.com/topic/11982-240z-weight/#findComment-86884
Don't forget that the Works rally 240Z's were fitted with 100 Litre fuel tanks. They even stepped up to 120 Litre tanks later. Imagine the weight of a full tank...........
They also - usually - carried two spare wheels and tyres, and some extra kit on the back.
Probably safe to say that precise weight distribution / corner weighting was not a priority on Works rally cars of that period.
https://www.classiczcars.com/topic/11982-240z-weight/#findComment-86889
  • Who's Online   1 Member, 0 Anonymous, 1,297 Guests (See full list)
