Dampening oil added to strut housing between cartridge and housing:
I recently had to change the shocks in my Z, and the previous owner
had changed the shocks about 3-5 years before, and he had not put any
oil in the shaft the strut cartridge had gone in. The Cartridge over
time had fused to the strut most likely do to excessive heat, and a
lack of lubrication. As a result, this made this out to be a very
unpleasant experience for me after being in there for a while the
cartridge was stuck in the shaft to where it was VERY VERY difficult
to come out. In fact one of the four never came out.. even after the
strut had been heated with a torch (which was necessary on the others
to remove them) it never came out... I was really stuck because the
original strut was now damaged in trying to remove this cartridge, and
where was I going to get another one when I was getting this work done
with a friend, out of town, on the weekend??
I sooooooo lucked out that the Nissan dealer had an original brand new
strut tower that you could no longer order sitting on the shelf
because it was ordered 5 years before, and was never picked up. This
was the original style with a non cartridge style shock already in it,
but since I was using the same Tokico shock on the other 4, just a
cartridge version it didn't matter.. I can just put in a cartridge
style in there next time it needs to be changed.
>>>>>>>>>>>>>>>>>> Original Message <<<<<<<<<<<<<<<<<<
On 5/1/00, 6:31:15 PM, Mike Gholson <mtg@mgdesign.net> wrote regarding RE:
<240z-club> Rear Struts:
> -- Group Message from Mike Gholson <mtg@mgdesign.net> --
> It is my understanding that you shouldn't need to add any
> oil with MODERN strut cartridges.
> The manual recommends it because the older struts depended
> on the oil for heat dissipation and lubrication of the shaft.
> Again, this is MY understanding. smile.gif I could be totally off.
> But, I didn't add any oil to my new Tokico Illumina's because
> of this advice.
> [m]
> > -----Original Message-----
> > From: Panos A. Rontos [maimailto:Prontos@gte.net]
> > Sent: Saturday, April 29, 2000 11:02 AM
> > To: 240z internet club
> > Subject: <240z-club> Rear Struts
> > -- Group Message from "Panos A. Rontos" <prontos@gte.net> --
> > I know that this has been covered; however, my computer has
> > gone through at
> > least one rebuild since then and I have lost the message. The Datsun
> > service manual states I should pour 400cc of geniune Nissan
> > strut oil or
> > equalivant into the case for cooling. Any suggestions as to
> > what to use?
-- Group Message from "Pete Paraska" <pparaska@tidalwave.net> --
Mike Gholson <mtg@mgdesign.net> wrote:
>Is this really a concern if you purchase a high-end strut
>cartridge? I figure that their engineering methods would
>lessen this possiblity.
Strut cartridges and shocks convert mechanical energy to heat.
The amount of heat generated is proportional to the damping.
Damping is the mechanical energy involved and has to do with
the force (related to the Illumina's setting), velocity and
translation of the two ends of the "damper".
I don't have handy any numbers on what the amount or rate of
conversion of this heat is for different driving conditions,
but it's not inconsequential. I wouldn't bet that air alone
is enough to convect the heat away quick enough from the strut
cartridge body to the strut tube during spirited driving. The
amount of connection between the strut tube and cartridge is
minimal for conduction heat transfer.
Any racers here want to chime in?
©The Internet 240z-Club - Our Web Site: http://www.240z.org
Our Bulletin Board: http://www.240z.org/forums.htm
Send your Email messages to: mailto:240z-club@peak.org
OK, chiming in...
FYI... my Tokico Illuminas are in the struts dry. Purely a maintenance,
cleanliness issue.
Shocks heating up and loosing effectiveness is not really an issue in autox
because you have time between runs for everything to cool down. Tire
overheating will occur way before you have any issues with the shocks. At
the MSA autox last Saturday I did 6 back-to-back 46 second runs and greasy
tires ended my fun, not the shocks getting hot. Also, I've run 20 and 30
minute track sessions at Buttonwillow and WSR and hot shocks were never a
concern.
But, Peter is right from a theoretical point of view and if I was building a
rally 240Z I would definately do everything I could to cool the shocks.
John Coffey
johncof@veriomail.com
-- Group Message from Rob Harville <RobH@Insynq.com> --
I would think shock overheating would be much more of an issue in off-road
racing like the Baja series. They have MUCH more suspension travel and at
high speeds. The tire heating isn't as much of an issue because of the
loose "track" surface. This is why they run remote-reservoir shocks with a
very high oil capacity w/ coolers on the reservoirs. I've never heard of
this being an issue with NASCAR, CART or INDY. Even with autox, there just
isn't enough constant full-travel articulation.
> How about every-day drivers? Or, weekend excursions along
> the coastal highways?
If I can't heat these things up at an autox or a track like Buttonwillow
then I don't think a street driver can do it, unless they are driving fast
over the pot-holed roads of Detroit. You would need a lot of low frequency,
large travel or high frequency, short travel inputs to start generating
heat. You really aren't much of that on the street unless the road are
really bumpy. Also, have you driven Pacific Coast Highway lately? You'll
spend most of your time going < 25mph behind a Mini-Winnie watching two
brats smear food on the back window while Dad drifts into oncoming traffic
at each corner.
Now, I WOULD put some oil in there to avoid the corrosion issues mentioned
in a previous post.
John Coffey
-- Group Message from RICHARD SCHULZE <richard@eoa.com> --
Dear Group:
Pete hit the nail on the head! The energy generation from shocks is not
inconsequential. As a Mechanic, I always put a little oil in the strut
housing when replacing inserts. Now I find that many Auto manufacturers
are designing and making Hybrid cars that are gas and electric. They
gain efficiency by recouping wasted energy. One of the prime waist
sources is the cars kinetic energy which is converted into brake heat
every time you stop. On the hybrids, when you hit the brake pedal, a
generator is linked to the drive line which drags the car down while
producing electricity to charge a battery pack. One of the biggest
secondary sources of wasted energy is shock absorber dampening. The
makers of Hybrids are designing shocks that are like linear motors which
get their dampening from electro magnetic repulsion while generating
electricity for the batteries. There is a significant amount of energy
coming from these shock and good heat dissipation will extend seal life.
Richard Schulze
  • 1 year later...
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
