Steve,
The answer to your question is explained http://www.zhome.com/
scroll down to the Classic and Restoration section and you will find a blurb on hub caps. The D caps essentially came with the hatch vent cars and the Z caps came with the round vent cars. D caps for 70 and 71 cars - Z caps for 72 and later.
https://www.classiczcars.com/forums/topic/12314-hub-caps/#findComment-86219
I was afraid I was giving you bad news. Your Z caps will probably get more valuable as time goes on. Hang on to them.
If you do go looking for D caps, there are two types. The earliest type have separated spring tabs for fitting on the rim. They were quickly replaced by the continuous spring tab type because they had a tendancy to fall off. If you find a set of early types, let me know and I'll trade you. Technically, your car should have the later type.
Chris
https://www.classiczcars.com/forums/topic/12314-hub-caps/#findComment-86320
Oh well, I'm not too worried about the hub caps for now. Eventually I may replace them, but the ones I have are OK. I bet the original ones fell off the car and the PO went to the Datsun dealer and that's what they had in stock. I like the rims that are on your car; maybe I'll save up for a set of those. The car has other little issues that need attention now, new brake hoses, water pump that leaks, a fuse that keeps blowing....:cross-eye
https://www.classiczcars.com/forums/topic/12314-hub-caps/#findComment-86374
