Originally posted by tmh708
If anyone has information or where to look please lend some assistance. 70-74 L20 6cyl. Thank you
Your best bet for the long-term would probably be to try and get hold of the Nissan engine Service Manual that covers the L20A engine ( as well as the L24, L26 & L28 ). This has ALL the data that you will need to have if you are the owner of one of these engines.
Nissan publication number SM8E-0L28G0 was published through the 1990s, and you might be able to special-order a copy through your local Nissan dealer.
Failing that, you might find one on ebay or at a specialist automotive literature dealer.
Nissan quoted the stock figures for the L20A as 130 bhp at 6000rpm and 128 lb/ft at 4400rpm.
https://www.classiczcars.com/topic/12346-l20-specs/#findComment-87294
No figures for bone-stock USA-market cars on the same day? That's a pity.
I thought it would be useful to compare the stock L20 figures with the stock L24 figures on the same dyno on the same day.
kmack, what kind of figures would you estimate for your transmission losses? And did you feel like the dyno was reading high, or low?
Alan T.
https://www.classiczcars.com/topic/12346-l20-specs/#findComment-87639
Alan T.
I have not seen very many stock 240's here in Texas. This post has my current setup: L24 Horsepower page 2, about half way down, posted 6/7/04.
I agree it would be useful to see a comparison, but most people running a stock car, would not be likely to put it on a dyno. At least that's the way I see it.
As for what my losses are, I'm not really sure. I just figure about 18%, which I guess is about standard. But that puts my crank output near 165 hp. Much higher than Nissan stated. So who knows? I do think the dyno was reading about right. There were a few Z32's that were they were supposed to be, at least according to the owners.
https://www.classiczcars.com/topic/12346-l20-specs/#findComment-87642
  • Who's Online   0 Members, 0 Anonymous, 1,142 Guests (See full list)
