I've found that I'm missing the fan shroud and splash shield under the radiator. I would also like to find some new 240Z and Datsun emblems for the rear hatch and a new hood emblem. Is any of this available through reproduction? Can somebody point me towards some sources?
thanks,
Devin
https://www.classiczcars.com/topic/1241-need-more-pieces/
Well, if you want new reproductions Motorsport Auto has the emblems. They have new fan shrouds too if you can't find a good used one, there should be something in the For Sale forums that is being stripped that might have a shroud.
Victoria British may also have everything you need, but since I deal with MSA I know that most everything you will need is available from them.
https://www.classiczcars.com/topic/1241-need-more-pieces/#findComment-4827
Motorsport Auto and Victoria British can both be found in the web-links section here. You can request a catalog on their web-sites. Neither have on-line ordering yet.
You could also look in there and take a look at strictlyz and zparts.com
You may be able to find what you need there. There are quite a few suppliers to choose from when searching for Z parts, new or used, so take a look around, you can find most anything you might need.
https://www.classiczcars.com/topic/1241-need-more-pieces/#findComment-4865
  • Who's Online   2 Members, 0 Anonymous, 1,464 Guests (See full list)
