1972zed Posted May 26, 2006 Share #13 Posted May 26, 2006 ...and on a related note, a guy at one of my rental properties left me title to his 1980zx 2+2 said it wouldnt work. I put a battery in it and started it up after a bit of fiddling with the ground wires. He said it needed a clutch, I pressed the clutch in and it just stayed there (at the floor after I attempted to let it out), I was able to engage it in reverse but after that no luck. I wonder if it is a worn out clutch, or something else clutch related....any clutch experts out there? Link to comment https://www.classiczcars.com/topic/12434-need-to-replace-clutch/?page=2#findComment-168837 Share on other sites More sharing options...
jmortensen Posted May 26, 2006 Share #14 Posted May 26, 2006 That last bit with the 280ZX sounds like a hydraulic issue. The clutch hydraulics consist of the master cylinder, the slave cylinder, and the hard and soft lines that connect them. Usually the master and slave are both replaced together. The hard clutch line is almost never an issue, and the soft line down by the slave can be inspected for cracks and leaks and replaced if need be.Your 240 clutch kit should have come with an alignment tool also, so you probably don't need to worry about going out and getting one. Link to comment https://www.classiczcars.com/topic/12434-need-to-replace-clutch/?page=2#findComment-168840 Share on other sites More sharing options...
agemeansnothing Posted May 26, 2006 Share #15 Posted May 26, 2006 I am listenen because I have to do the same. Link to comment https://www.classiczcars.com/topic/12434-need-to-replace-clutch/?page=2#findComment-168843 Share on other sites More sharing options...
ZCCOR#109 Posted May 26, 2006 Share #16 Posted May 26, 2006 ...and on a related note, a guy at one of my rental properties left me title to his 1980zx 2+2 said it wouldnt work. I put a battery in it and started it up after a bit of fiddling with the ground wires. He said it needed a clutch, I pressed the clutch in and it just stayed there (at the floor after I attempted to let it out), I was able to engage it in reverse but after that no luck. I wonder if it is a worn out clutch, or something else clutch related....any clutch experts out there?There may be one of several issues hereone I have seen/read about is the clutch disk rusting to the flywheel/and/or pressure plate. The other is the hydrolics going bad/dry/air in lines.So, flush the master cylinder and slave cylinder\ with new fluid. Get a friend to push the clutch pedal while you open and close the bleeder valves.Observe the slave cylinder moving the clutch release lever on the side of the bell housing. If it does, then the issue would seem to be in the clutch itself.Maybe the return springs on the clutch pedal, or the slave cylinder are missing or broken. crawl under the dash and car to observe Link to comment https://www.classiczcars.com/topic/12434-need-to-replace-clutch/?page=2#findComment-168845 Share on other sites More sharing options...
1972zed Posted May 26, 2006 Share #17 Posted May 26, 2006 Thanks guys, my impression was that it doesnt seem like the actual clutch but the hydraulics. I will look at that first since it is an easier/cheaper fix. Link to comment https://www.classiczcars.com/topic/12434-need-to-replace-clutch/?page=2#findComment-168848 Share on other sites More sharing options...
