Originally posted by MrMarcDude
how would i go about removing the rivets anyway? There is only a ding strip on one side. Looks kinda bad.
with a drill bit. You drill out the center of the rivet. Then you'll need to weld the holes in the sheet metal closed.
https://www.classiczcars.com/topic/12447-door-ding-strips/#findComment-87754
  • 3 weeks later...
I just had my 75 repainted, and removed and replaced the
ding strips myself.
Easy to do...drill out the old rivets and pop-rivet them back on
afta.
Be carefull when reattaching strips, so as not to scratch paint :(
Did that on first rivet...when gun popped off !
26thZ-- my Z looks like your color...what paint code ?
Mine is 303 . Emerald Green
https://www.classiczcars.com/topic/12447-door-ding-strips/#findComment-89083
Removed them so the paint job would be better ( less masking,etc )
Put them back on cause I don't dislike the looks..and they were a normal
dealer accessory in the mid 70's, so to remain "true to the period".
Also, they were in great shape...chrome tips and vinyl inserts just like new.
https://www.classiczcars.com/topic/12447-door-ding-strips/#findComment-89133
