  • 1 month later...
Eric,
Just been flicking through these posts for info on 40phh models and came across your unanswered post.
From "How to modify your Nissan/Datsun OHC engine" by Frank Honsowetz on page 111.
"For an initial main-jet size, start with 0.04 the size of the main venturi. Eg, if a 40mm main venturi is used, install a 1.60mm main jet, or 40x4 divided by 100 = 1.60mm For an air-correction-jet size, add 0.20 to the initial main-jet size. Eg, install a 1.80mm air jet, or 1.60mm + 0.20mm = 1.80mm"
Not too sure if that helps you any?
Anyway you have probably sorted it already!
  • Who's Online   0 Members, 0 Anonymous, 1,366 Guests (See full list)
