59ghia Posted July 29, 2004 Share #1 Posted July 29, 2004 Hello fellow Zers I've got an opportunity to pick up a clean late '72 early'73 bumper. Although they look the same except for the larger overiders, the mounting point inside the bumper is different. The early bumpers have the studs permanently mounted to the bumper itself, were the late 72, June or July has the mounting bracket studs mounted thru the overiders on an adaptor. Has any one tried to mount these late '72-73 bumpers to an earlier car? I'm getting close to desperate to find a clean early bumper, and thinking I may need to do some mods to get this to work.Thanks in advance,Dave Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/ Share on other sites More sharing options...
dk240z Posted August 4, 2004 Share #2 Posted August 4, 2004 Yes!Did mine about a month ago. Had an extra set of '72 bumper brackets, and a rechromed '72 bumper laying around, so I went after it. Just unbolt the '73 assembly at the two mounting points inside the front fender wells. Don't forget to unbolt the bumper end to fender bolts, also inside the fender well.Remove the two filler pieces, and bolt up the '70-'72 front bumper assembly. The '70-'72 backets fit inside the grill-underhood area. Nissan was nice enough to leave these threaded holes in the '73. Wish I had some pics, but I feel confident that you can do it. Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-89811 Share on other sites More sharing options...
hls30.com Posted August 4, 2004 Share #3 Posted August 4, 2004 DK240Z is dead on! Will Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-89852 Share on other sites More sharing options...
dk240z Posted August 5, 2004 Share #4 Posted August 5, 2004 By the way:I used my extra '70-'72 front bumper guards since the '73 guards were gone when I bought the car. '73's should work though. Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-89993 Share on other sites More sharing options...
59ghia Posted August 5, 2004 Author Share #5 Posted August 5, 2004 Ok, But how about putting a '73 bumper on a '72 ? Get rid of the big overiders, and the bumper is basically the same, except the attachment method (bumper side)Dave Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-89994 Share on other sites More sharing options...
dk240z Posted August 5, 2004 Share #6 Posted August 5, 2004 Forget it!Unless you have a mig welder and air tools, you'll have to cut off the bumper end brackets, and flip them. Then remove the '73 front mounts, and fab some kinda mount for the '72 brackets. It can be done if your patient, and have the right tools. Hell, just buy a nice used '72 bumper off Ebay. Life is too short! See ya. Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-89995 Share on other sites More sharing options...
59ghia Posted August 6, 2004 Author Share #7 Posted August 6, 2004 I hear ya! I'm just getting kinda desperate for a bumper! Oh well, patience is a virtue Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-90015 Share on other sites More sharing options...
dk240z Posted August 6, 2004 Share #8 Posted August 6, 2004 I tell ya;Put that '73 bumper on Ebay! That thing's worth more than a nice '70-'72 bumper. It was only made for one year model, so there are purists out there looking for it. Sell it, take the money and buy a nice'70-'72 on ebay and your all set. See ya. Link to comment https://www.classiczcars.com/topic/12696-73-to-72-frt-bumper-swapdoable/#findComment-90064 Share on other sites More sharing options...
