My old four speed is making some very strange noises and I think its time to build up my L-28 and mate it to a ZX 5 speed and swap out all of it at one time. I know I have to use 280 clutch components, but something in the back of my mind says I also have to change out a structural piece. I know about the mod to the transmission tunnel but what am I forgetting? :paranoid:
https://www.classiczcars.com/topic/12770-l-28-and-zx-transmission-swap/
  • 2 months later...
when you say ZX I assume you mean 79-83 280ZX? in which case all the clutch components swap over just fine, all 70-83 N/A cars used a 225mm flywheel/clutch, all Turbo and 2+2 models used a 240mm flywheel/clutch, the turbo used a T5 tranny which will require you to modify your trans crossmember and have a custom driveshaft made casue the 280ZXT used a unique output spline, the throwout collar was made a bit longer at some point I am thinking 72 was the first of the longer throwout collars and they stayed the same size through 83
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
