You must have a 70 or 71.There are bushing you can replace,but that tranny is known for your problem.I replaced every piece rubber and metal in the shifter of a 70 I restored once.It was still hard to tell neutral from in gear.On the bright side welcome to the world of Z cars.You can easily upgrade to a better tranny! Have Fun!! Daniel
https://www.classiczcars.com/topic/1299-shifter-slop-fix/#findComment-5156
Well, if it is the original trans you have the A type transmission. Unfortunately the A type has the worst shifter, it is a very simple swap to put the later B type model 4 speed in or you could swap to a later 5 speed.
Of course you could just re-build the shifter on the A type, not sure the complete list of parts you need as I have taken out the A type from my car and am going to replace it with the B type. The internal shift rail on the B type gives a much better feel to the shifter. Not as much slop, and it is a bit stronger than the A type.
https://www.classiczcars.com/topic/1299-shifter-slop-fix/#findComment-5165
SirJester,
You can put in a later 4 or 5 spd. The problem is the hole where the shifter comes through the tunnel is located dirfferently on the A type trans that came in a 70. Youwill have to cut out some of the tunnel, and I think trim some of the console too.
That is what keeps me from putting a 5spd in my 70. It boils down to how original do you want to keep your car.
The website that was mentioned has a lot of good info. Check it out.
Marty
https://www.classiczcars.com/topic/1299-shifter-slop-fix/#findComment-5206
  • Who's Online   2 Members, 0 Anonymous, 1,172 Guests (See full list)
