A handy hint to lube the wire ''cables'' for the choke is to take a straw and with the cables proped up , obviously they must be disconnected from the carbs. use the straw and tape it to the end and oil the cables and let stand over night. Works good on the hood release cable also. While you are at it attaching a length of small cable, I used the kind that is ment for picture hanging, to the hood release and run it thru the firewall and let it hang above the foot peddles out of the way . If the regular hood release fails this cable will save one hell of a lot of grief. :)
