Gee Posted May 19, 2005 Share #25 Posted May 19, 2005 It could be that the heater hoses (that run behind your dash) are leaking. Sounds like more time spent upside-down under the dash fixing stuff!! Link to comment https://www.classiczcars.com/topic/13053-turn-signal-lever-is-mushy/?page=3#findComment-124446 Share on other sites More sharing options...
dhoneycutt Posted March 2, 2006 Share #26 Posted March 2, 2006 Either I am not searching the correct words to find it or I am imagining things. Awhile ago some one posted a "how to " on taking apart, reconditioning, and putting back together a turn signal switch. Does anyone know what happened to that article? I would like to try it on a spare t/s switch that I have that doesn't work and the one I am using is showing signs of failure (possibly). Link to comment https://www.classiczcars.com/topic/13053-turn-signal-lever-is-mushy/?page=3#findComment-157864 Share on other sites More sharing options...
montoya_fan01 Posted March 2, 2006 Share #27 Posted March 2, 2006 Wasn't it an article on refurbishing the Headlight Switch? Link to comment https://www.classiczcars.com/topic/13053-turn-signal-lever-is-mushy/?page=3#findComment-157865 Share on other sites More sharing options...
dhoneycutt Posted March 2, 2006 Share #28 Posted March 2, 2006 Wasn't it an article on refurbishing the Headlight Switch?I found that one real easy. Again, I may be mistaken. I just thought that someone did a refurbish on a t/s and I was looking for it. I am also looking on some other forums also. just to be sure. Link to comment https://www.classiczcars.com/topic/13053-turn-signal-lever-is-mushy/?page=3#findComment-157866 Share on other sites More sharing options...
yukonharry Posted March 22, 2006 Share #29 Posted March 22, 2006 Check/clean/replace your 4 way hazzard switch. If that doesn't work, your turn signals won't work either. That's why they worked intermittenly when you jiggled the wire bundle to the console. This is a common cause that has people pulling their hair out. Link to comment https://www.classiczcars.com/topic/13053-turn-signal-lever-is-mushy/?page=3#findComment-160391 Share on other sites More sharing options...
wa5ngp Posted March 23, 2006 Share #30 Posted March 23, 2006 While you are doing all this it might be a good time to put relays in there to take the load off the light switch mechanism. If you upgrade to quartz headlamps ultimately that switch is going to give you trouble. Furthermore, if you go with the relays your headlight brightness will be a lot better and you can take a big load off the fuse box so it won't get so hot. There's lots of how to posts on this.Don Link to comment https://www.classiczcars.com/topic/13053-turn-signal-lever-is-mushy/?page=3#findComment-160616 Share on other sites More sharing options...
