I am having troubles with my left rear brake light. I just replaced the stop light switch, but that only fixed the right brake light. All my blinkers, hazard, tail, and head lights are working. I think its the hazard relay switch but am uncertain. Any help would be greatly appreciated.
Thanks,
Hunter
https://www.classiczcars.com/topic/13070-brake-lights/
  • 4 weeks later...
Check the fuses. I had a very similar problem with my brake lights and them not illuminating. I replaced the fuse and they worked wonderful. I believe it is the fifth fuse down on the left side on a 240. Chances are it is not a fuse becasue you have one brake light working but it is worth a try.
https://www.classiczcars.com/topic/13070-brake-lights/#findComment-96232
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
