Hunter21 Posted August 30, 2004 Share #1 Posted August 30, 2004 I am having troubles with my left rear brake light. I just replaced the stop light switch, but that only fixed the right brake light. All my blinkers, hazard, tail, and head lights are working. I think its the hazard relay switch but am uncertain. Any help would be greatly appreciated.Thanks,Hunter Link to comment https://www.classiczcars.com/topic/13070-brake-lights/ Share on other sites More sharing options...
AChev Posted September 23, 2004 Share #2 Posted September 23, 2004 Check the fuses. I had a very similar problem with my brake lights and them not illuminating. I replaced the fuse and they worked wonderful. I believe it is the fifth fuse down on the left side on a 240. Chances are it is not a fuse becasue you have one brake light working but it is worth a try. Link to comment https://www.classiczcars.com/topic/13070-brake-lights/#findComment-96232 Share on other sites More sharing options...
seerex Posted September 24, 2004 Share #3 Posted September 24, 2004 also remove the bulb as well and clean the connections at the bulb and rear harness , also test the circuit to see if you are getting any juice when the brakes are applied to that bulb socket first then work your way back Link to comment https://www.classiczcars.com/topic/13070-brake-lights/#findComment-96243 Share on other sites More sharing options...
