Then you can cut the arm off of the vacuum advance dashpot, and just leave it attached to the side of the distributor (or plug the hole if you prefer). Now you have a distributor with mechanical advance and no vacuum advance anymore
The dizzy on my 280Z has the centrifugal weights inside, but I don't see how they connect to the breaker plate to affect the spark advance? Any explanation on that before I reassemble? ( got my breaker plate- it's the "last one left in the U.S.")
thx
The distributor shaft is two pieces, the top that holds the reluctor can rotate up to 8.5 degrees independently from the bottom. The mechanical advance weights and springs are what controls the rotation. So the breaker plate has nothing to do with the mechanical advance. It is just a place to mount the stator to (if you've disabled the vacuum advance).
  • Who's Online   2 Members, 0 Anonymous, 1,356 Guests (See full list)
