I don't think there is anything that is supposed to go in between the two. But, if you don't then eventually the guards will scratch the bumper leaving marks. I have seen where someone has taken some 1/4" clear tubing and cut it down the center (lengthwise). Then you put the tube over the edge of the guard. Now you have the tube between the guard and the bumper to prevent scratches.
Thanks for the info. Another thing that came up is that the "new" bumper guards don't seem to have all the holes in them to put on the rubber strips. There are indentations where the holes should be but it looks like they were never punched or drilled out during manufacturing. I purchased these from MSA and they came in the Nissan box. They fit the bumper perfect. Is it normal to have to drill these out to fit the rubber strips?
Greg
