I have a pin remover that really makes the task easy . I have the specks and parts list . If some one has access to a welder and a lathe it is a simple devise to make . I aquired the one I have from a member with the understand that I would have it for loan to the members. However the shipping cost to oz makes this a nonissue. let me know if someone would build one for the use of our members in oz. The tool is made from a 12''length of 2'' steel tubeing about 14'' of hardened all thred and some washers and a few nuts . 1, 4'' length of bar stock taped to fit the spindel pin on one and attached to the allthread . This part the taped piece of bar stock is the hardest part to make . There is a member over here that is going to make a puller for himself If any one is interested mabey he would turn one of the barstock parts for you . The member I got mine from had at least one of the complete tool for sale for $85.00. Let me know and send me a PM . Gary
https://www.classiczcars.com/topic/13212-spendle-pin-remover/
That's an excellent idea Gary! It'd make life a hell of a lot easier for many of us. Unfortunatly I don't have the equipment or experience to make such a thing myself. Although, if none of the other aussie members are able to I'll, see if I can line up someone around here to do it.
Edit: My pins (rather stuborn ones at that) were removed recently (with about 20 ton on the hydraulic press and 5 min of heating) so I don't have a use for the tool atm, but I'd still be happy to go ahead with this if no one else does.
  • Who's Online   2 Members, 0 Anonymous, 1,511 Guests (See full list)
