Removing Rusted or Otherwise Stuck Nuts/Bolts
I have been using kroil and PB blaster for quite a while and I like the use of kroil the best .But as was mentioned I have only found it on the net. I stay away from silikroil because of the silicone and if you ever want to paint the part it is such a pain. The Blaster I think works as good as kroil but PB stinks to high heaven. My garage is attached to the house and the smell is a real factor for me. As some one just mentioned , WD-40 is only used on toys and fish bate , by the way dont use WD on reels or guns It will gum everything up after they sit a while. Gary
Chloe used to be able to get almost all of the bolts for the cars. Getting your neighborhood Nissan dealer to expend the effort to look up the P/N's is going be the tough part of trying to get them now.
Another reason not to use WD-40 on your gun: WD-40 is a penetrating oil. Which in plain english means it's a real thin oil. If used on a gun the oil can work it's way into the primer of the bullet, thus rendering the bullet usless.
$ 0.02
And then you won't be able to shoot the rusted bolt off!!!
Less than a month ago, I took off the nuts on my Datsun 280Z bumpers. Those bumper nuts are abso-friggin-lutely rusted solid. There's so much rust, some of the threads on the bolt actually disappeared. Most of the corners on the nuts disappeared into rust as well. I didn't know there are products such as Blaster, so I didn't try them. What I used were nut extractors from MasterCraft(you know, the kind that looks like a nut, but with 6 spiral cutting edges instead of threads)
I used a steel brush to clean up the threads as much as possible, then spray lubricant on the joints. Put the extractor on, sometimes tap it in gently to make it fit over rusted nuts. Take out your biggest crescent wrench, turn the extractor while applying pressure on the extractor, forcing it to bite into the nut. Slowly add torque as you turn to prevent slipping. It had worked very well for me, but I use it as one of the last resorts. The very last resort is an angle grinder.
Having worked on Rusty Z's since the late 70's, I used a whole lot of WD-40, with very mixed success. When I started taking #215 apart, I asked the same question here, and was led to PB Blaster or Kroil. I tried Kroil, and I will NOT go back to WD-40. There is no comparison on the effectiveness. Before I received the Kroil (mail-order), I also tried some penetrating oil from the local hardware store. Worked better than WD-40, but still nowhere as well as the Kroil. Haven't tried the PB.
Mark
  • Who's Online   0 Members, 0 Anonymous, 1,570 Guests (See full list)
