Important Grounding Points
Just as a note, there is another way other than a multi meter to check for loose or open ground connections. Use a 12 volt light probe. With it connected to a known good battery ground, touch around the bare wires and look for a light. While it cannot not give you an exact ohm reading, at least you can find an obvious open circuit that is supposed to be grounded..
Using that procedure is better than using a multimeter because a multimeter will not subject the tested path to a load, which the filiment of a bulb does. Occasionally a connection(especially an old one, will ohm out good, but fail when a load is placed on it.
Will
  • 2 months later...
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
