Anybody know where to start looking for the oil pressure sensor on a Ford 460?
I have a motor home on an '85 Ford E350 chassis with a 460ci engine. I need to re-wire the electric fuel pump but I don't where on the block the oil pressure unit is. I want to wire the fuel pump so that it will only run with oil presure or while the starter is engaged. The starter part is easy. Anybody got any ideas where to look?
https://www.classiczcars.com/topic/13504-oil-pressure-unit-ford-460/
