Does anyone out there know the spring rates for Tokico Springs and Suspension Techniques Springs. I figure since I'm getting shocks from OS, I may as well look into springs as well.
I read last night that the ST springs are around the 200lb/in mark, but I want to confirm this. No idea about the Tokico springs though.
I have decided on Tokico HP shocks, so they should suit either of these quite well yes.
If I keep pestering everyone with suspension questions long enough, I might get what I am after.
Thanks
Scott
According to MSA, the Tokico's are 140 lbs in front and 165 lbs rear. The MSA springs are 129/188. Another member told me once that ST's were 160/200.
I have Tokico HP'S with Stage I Euro springs 101/112 (with oem rubber bushings), and they are plenty stiff for a street car. It does handle very well and corners flat. 200 lb springs would be VERY stiff on the street.
I had a discussion with another member recently about springs to use on my track car, which is about 60-70% street driven. We decided the ideal rates would be about 129/165. Now if I could find somebody that made a set at the those rates (basicall hallf Tokico, half MSA)!
Just some info and my opinion.
Marty
