At least on the 280Z, there is a vacuum thingy controlled by the vacuum solenoids to increase the idle speed when the a/c is on. Since I have no a/c, I took that off, along with the EGR which wasn't workling. I might put it back on to see if it would help, since it was sucking fresh air and not connected to the exhaust manifold. :(
https://www.classiczcars.com/topic/13611-best-idle-speed/#findComment-98271
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
