webdawg1 Posted October 24, 2004 Share #1 Posted October 24, 2004 Just a little bit of "Trivia". Was out in the garage today cleaning up spare "Theromotime Switch" (I.E. - Contact cleaning for connector, Brass body for switch...etc...etc) When I started cleaning on the brass body I started to see letters and numbers on the flats. After I cleaned it a little bit more I saw the following info:Made in Germany ????11.74150 degree's C max12V 40WVDO 36/4/1418 Degree's C 12 secJust curious to see if anyone else has ever noticed this "Made in Germany" info, as I was expecting it to say something like "Made in Japan" or something to that effect.webdawg1 Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/ Share on other sites More sharing options...
Zrush Posted October 24, 2004 Share #2 Posted October 24, 2004 Isn't the fuel injection on the Z's a "Bosh Jetronic" or something like that? Bosh isn't a Japanese brand either. Yes, No?Vicky Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-99339 Share on other sites More sharing options...
webdawg1 Posted October 25, 2004 Author Share #3 Posted October 25, 2004 Actually I believe they called it "L-Jetronic" which was developed by Bosch in Germany. According to the EFI theory/troubleshooting manual (PDF format) that I downloaded, 1975 was the first year that the "L-Jetronic" was imported into the USA. I was just kind of surprised that the "ThermoTime Switch" actually said "Made in Germany" on it...Things that make you say things like "Say What"....webdawg1 Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-99450 Share on other sites More sharing options...
sblake01 Posted October 26, 2004 Share #4 Posted October 26, 2004 Well the Nissan F.I. system is based on the Bosch L-Jetronic fuel injection used on BMW, Mercedes etc. But it is their own version of the system. Through the years, parts have been interchanged such as the air regulator, the thermotime switch, the temperature sensor, etc. with the German counterparts. The Nissan parts were made by JECS. The Bosch parts are interchangable and, in my opinion, better. If you have a VDO (German) thermotime switch, it has been changed from the original JECS (Japaneese) thermotime switch. The German parts were common replacements on the 280Z, 280ZX, 810, 910 (Maxima) and any of the other 4 or 6 cylinder cars with L or Z (N.A.P.S.) engines. My own personal research which spans about 15 years now does show that the German parts actually last longer. The thermotime switch and temperature sensor from any of the late 70s to mid 80s BMW 6 cylinder engines work on any of the L series f.i. engines but only the air regulator with the number '0 280 140 124' will work on the Z engine. I believe that one comes from the 80 to 83 BMW 6 cyl. Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-99463 Share on other sites More sharing options...
wm_e_smith Posted July 26, 2005 Share #5 Posted July 26, 2005 Well the Nissan F.I. system is based on the Bosch L-Jetronic fuel injection used on BMW, Mercedes etc. But it is their own version of the system. Through the years, parts have been interchanged such as the air regulator, the thermotime switch, the temperature sensor, etc. with the German counterparts. The Nissan parts were made by JECS. The Bosch parts are interchangable and, in my opinion, better. If you have a VDO (German) thermotime switch, it has been changed from the original JECS (Japaneese) thermotime switch. The German parts were common replacements on the 280Z, 280ZX, 810, 910 (Maxima) and any of the other 4 or 6 cylinder cars with L or Z (N.A.P.S.) engines. My own personal research which spans about 15 years now does show that the German parts actually last longer. The thermotime switch and temperature sensor from any of the late 70s to mid 80s BMW 6 cylinder engines work on any of the L series f.i. engines but only the air regulator with the number '0 280 140 124' will work on the Z engine. I believe that one comes from the 80 to 83 BMW 6 cyl.I have owned for 26 years a 1978 Datsun 810 (L24, 6 cyl, efi, California Model, sedan, manual transmission). A local parts store has told me they can order a Thermotime switch for a 1982 or 1983 BMW 528e. I interpreted your reply as saying that this would be acceptable as a replacement for my old thermotime switch. Are the cold start valves also interchangeable?Thanks, Bill Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-132098 Share on other sites More sharing options...
sblake01 Posted July 26, 2005 Share #6 Posted July 26, 2005 Never tried one. If it has the same configuration as far as design, mounting, electrical connection, I don't see why it wouldn't work. Put up a picture of that 810. I also own one (a 79 2 dr Cali Model). Don't see them very often. Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-132133 Share on other sites More sharing options...
TomoHawk Posted July 27, 2005 Share #7 Posted July 27, 2005 only the air regulator with the number '0 280 140 124' will work on the Z engine. I believe that one comes from the 80 to 83 BMW 6 cyl.Is that the AFM? I would probably like to have one on hand, just in case. Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-132191 Share on other sites More sharing options...
sblake01 Posted July 27, 2005 Share #8 Posted July 27, 2005 Is that the AFM? I would probably like to have one on hand, just in case. No, that's just the air regulator or auxiliary air valve. It adds extra air to the mix to help the engine warm up. Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-132211 Share on other sites More sharing options...
TomoHawk Posted July 27, 2005 Share #9 Posted July 27, 2005 Oh, that. Mine wasn't working, so there's a new one in there now. Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-132214 Share on other sites More sharing options...
sblake01 Posted June 26, 2006 Share #10 Posted June 26, 2006 I was looking at this old post and I noticed that my description of what the auxiliary air regulator does was wrong. I doesn't add extra air to the mix, it bypasses the throttle plate which raises the idle speed. Maybe that's basically the same thing, however. Link to comment https://www.classiczcars.com/topic/13758-thermotime-switch-trivia/#findComment-172385 Share on other sites More sharing options...
