Converting E31 head to internal oiling
You should make sure when you seal off the original oil holes they are pressure tight to keep oil pressure.
I'm not 100% sure about having to drill holes as I was going to have to go the other way back to an oiler bar to fit a camshaft i picked up but changed my mind.
There is not really a major advantage however to me it seems like a more efficient way of oiling everything up top :)
If you are using the E31 head and mating to an original 2400 cc block you have a potential interference problem if exhaust valves are increased from the stock 33 mm dia to the later engine 35 mm dia. Adding a high lift cam aggravates the problem. Can be made compatible by notching the contact point on the rim of the block. Not sure what happens with the larger intake valves?
I upgraded my 2400 cc engine with MSA Schneider cam kit which is designed with internal oiling via holes in the cam lobes. Only mod required is to trash the external oil manifold and cover the two supply holes for same with block off plates.
Last month I replaced the oiler bar with another, since the previous one had the end (#6) cyl. almost apart. I guess this is common for the #6 oiler section to fall off. What is the thinking of removing the bar and blocking, taking away oilling from the top? :ermm:
Craig:
In addition to removing the spray bar, you must replace the current camshaft with one that provides for internal oiling. (i.e. oil is pumped into the camshaft and each cam lobe has a tiny hole in it where oil under pressure gets squirted out to lube the rocker arms and everything else up in there.
Advantage is that there is no longer a spray bar to crack and fall apart, robbing part of the cylinder head of life saving oil.
  • Who's Online   1 Member, 0 Anonymous, 1,346 Guests (See full list)
