I just purchased a lightened flywheel (used). It came out of a 240z. I have an 83 5 speed with 280z clutch parts (clutch collar, clutch slave cylinder,clutch fork) question is can I still use these parts with this flywheel?? Or do I have to buy new 240z clutch parts. I thought the flywheel was the same on the Z models through 83, except for the 2+2 versions. I seem to remeber that if you used the same year clutch with parts, you'd be fine. Is this correct??
  • Who's Online   2 Members, 0 Anonymous, 620 Guests (See full list)
