headers: 6 to 1 or 6 to 2 to 1
Installation would be the same on either one. I would suggest you install the headers (use high temp copper permatex sealant on the gasket) then take it to a muffler shop and have them build you a custom 2-3 inch exhaust (your choice on exhaust diameter). It will save you a lot of headache, you will only pay about $50 bucks more, and it will look 100 times better than the pre-bent kits.
$0.02
I second the motion on the four piece pre bent kit.
the one that I installed on my 70' had to be welded cause the clamps kept scraping the ground after I installed my new eibach pro-rate springs.
We took off the clamps and welded the whole thing in place. would have been better off goin to the shop and having them make one with a lot less parts to it. costs a little more but more worth it. mine is 2 1/2" pipe with a 6 into 1 header.
Dave.
  • Who's Online   2 Members, 0 Anonymous, 1,218 Guests (See full list)
