Good call Alex. They do a first rate job and it really IS guaranteed for life. Here's a tip for those who cruise the wrecking yards. If you find a GasTank Re-Nu tank for your car, the warrenty follows the tank, not the car! So your junk yard tank is as good as new, guaranteed! I was surprised by this fact. I brought them one of their tanks for repair, with cash in-hand, and was told "No Charge". Not used to that kind of treatment these days.
Just as a question , and not as a suggestion . Has any one tried the POR fuel tank repair kit?? I do know that there is a coating that is used by fuel tank builders that is pored into the tank and sloshed around and allowed to dry and it seals the tank. It is used to seal the seams that are welded. I dont know the name of the stuff . But if the tank is just rusty and coated with varnish and there is a remover offered and the inside is coated with a sealer that is made for that use , why wouldent that work ? If the rust is to a point that there are holes , that's another story. 3 to 7 hundred sounds like a lot of money for this.
