Hardest bolt or nut to get to?
I hate those stinking exhuast manifold bolts... we'll the ones that attach to the intake manifold... grr.. i hate those...
and also some of the screws under the dash by the heater core... by the heater hoses and stuff..
no i have a new one, i was replacing the oil pan gasket and there are hella bolts, at least 15 or 20, and a few of them are a total pain in the arse to screw in, you gotta hold them in a real loose, funky position with two of your fingers and try to screw them in enough untill you can use a tiny wrench and tighten them 30 degrees at a time
  • 2 months later...
I'd have to agree with the steering coupler bolts. There was one that was a real bitch plus you have to get some pressure on it while bending over into the engine bay! I fnally used a cigarette lighter to get it to come loose. Heat works well. After that, prob anything to do with the internal heater hoses.
having just finished a half day marathon change of steering column -i also vote steering coupler bolts...
although, for those of you attempting it, i had someone of adequate strength help (as my socket wrench could only get one click in, so that equated to about 1/12th of a turn each .. go. so i got it on and held it tight - and got someone to turn the steering wheel back and forth (get the front end off the ground). This made life a little easier.
but after that, anything under the infernal dash!
  • Who's Online   1 Member, 0 Anonymous, 1,445 Guests (See full list)
