The strapping is back threaded through a set of rings for adjustment. Zink plated... The extra slack length of black nylon strap is held with a black plastic ring. I see them on eBay quite often. They come in different lengths because the later series cars with tool bins forced the straps to be shorter. In other words, make sure you buy the long ones for the earlier cars. Of course, you could always have new straps made. Quite often, you see the hardware fairly rusted (go figure) and it all has to be re-plated anyhow. In most cases, I would just buy the cheapest ones you can find with decent hardware and have it all redone.
https://www.classiczcars.com/topic/14074-luggage-straps/#findComment-102719
