Green is anti-freeze. You will need to CAREFULLY examine the entire rear part of the engine, preferably while the engine is warm and cooling sytem has pressure built up (but not necessarily with the engine running). It is the engine cooling system that is leaking somewhere.
It could be (just to name a few things):
a heater hose
the metal pipe that goes around behind the engine to provide Intake/carb coolant.
a Freeze plug (may not be one of the ones visable without removing the trans)
a head gasket leak (seep) at rear of engine
Take your time, be thorough and you should be able to find the source.
Well, I said freeze plug because in the pictures it appeared to be coming from inside the mounting plate. If it was coming from the other mentioned sources wouldn't you be able to see evidence of coolant leaking on the mounting plate instead of just at the bottom?
Yes. The pictures only show the bottom of the engine (which is filthy, dude) and if the leak was from a hose, tube, or head gasket, the top of the engine would be wet.
yah, its pretty messy. I haven't had the time to get the underside cleaned yet. Most of that is dirt build up because it is always wet. That oil you see around the spout on the pan is not a leak, i just changed the oil 2 days ago and it was really windy, blowing it about everywhere.
  • Who's Online   2 Members, 0 Anonymous, 1,385 Guests (See full list)
