Any idea if this is true for a 73' or if the 73' even came stock with an E.P.?
Yes '73 came from the factory with an electric fuel pump along with the mechanical one. I word of caution all years 240Zs come with electric fuel pump wiring but not the rpm relay if it wasn't from the factory.
  • 6 months later...
For one thing the AC pump is a good pump if you can stand the noise. The stock electric and the one from the early '80s RX- 7 are turbine pumps and are pusher pumps and work the best near the tank and they are quiet. Always install a inline filter before the pump, they run at high speed and crud really messes them up. There is stock wireing on the '72 for a electric pump . you will find it wound up and taped with blue tape , just follow the sending unit wire up the side of the tank. I would remove the screens from the entake of the carbs and leave them out. I am running a electric only on my Z and have no problem. On another note try 20w in the carbs the 5w of the atf is too thin and can cause a lean condition off the line. Just for a split secound. By the way you should be able to find a RX-7 pump at the bone yard for about $15.00. I have tried this pump on a tripple set up and no problem , they put out right at 4psi. If you do the RX pump be sure it is from a carbed car not injected! my2c Gary LOL
Gary,
Any idea if an early '71 has the wiring for an electric pump built in? I need to get mine isntalled real soon.
Marty
Gary,
Marty
Yes it does, same as described previously, the other end of the conection is a wiring plug at the dash next to the heater console. The wires that need to be jumped are black and green. They are part of a plug that is located in the wiring bundle on the rh side. Make sure and fuse it, and use a relay for safety
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
