It rains in California? :rolleyes: I am so disillusioned...
To get the screws out of the fender panel that blocks access to the filler tube I recommend an impact driver.
I bought one of those years ago from JCWhitney, and it has become one of my favorite tools. I have rarely seen it fail to remove a rusted-in-place philips head screw. It looks like cross between a metal screw driver and a rachet. You just put the tip into the stuck screw and hit the end with a hammer. (There is usually a forward/reverse selection by twisting the end to the appropriate cam. I always have to push mine on the floor to make sure it is turning the right direction.)
Once you take out that panel, removing the filler tube is easy, particularly if the OEM hose clamp is still on there. Just grab it with some channel-locks and break it. (You can't really reuse it anyway.)
what i did was i put some of that stuff u put on rusty nuts. then i got teh dremel and cleaned up it. after that prep work it come off pretty easy. yea after that panel came off i could actually fit my hand in it. those clamps that have on the fuel lines suck. i guess thats old tech for u but i like the new ones where its just a solid metal clamp and u dont have to worry about the screw falling out.
You can take all the vent and overfill hoses down to the local NAPA store and if they're the friendly type, you can go through their hose supply and find the right hose that matches the bends in the more expensive ones ($90. for the long one!) The straight sections can be any good all-purpose fuel/oil line connected by plastic hose barbs. The gromments for the vent lines can be found at www.zzxdatsun.com look under rubber parts.
Here's the pics I promised. I know it's kinda hard cause you can't see the last bit of hose that connects to the tank but it's the best I could do without removing the tank ROFL In the first pic you can't see it but where it (the lower hose that doesn't have webbing) makes that first 90° bend towards the center of the car through the hole there's another 90° hose barb there as well.
Click on the pics for the larger images :classic:
th_654cf_Gastank_lines.JPG th_5dfc0_Gastank_lines2.JPG th_5df96_Gastank_lines3.JPG
Has anyone ever figured out how to eliminate that whole archaic setup? There must be an easier way to vent the tank no?
It's only needed for when you fill it up right?
I could be wrong but somethin's tellin me that it's not just for that...things expand when they get hot and on hot days that gas sitting in that metal tank is going to do the same thing which means the vapors need somewhere to go and if your gas cap is functioning properly well it ain't goin out that way LOL So I think it allows circulation so to speak and possible controlled venting ?? If someone knows for sure please correct me if I'm wrong :nervous:
i see u upgraded those clamps to modern ones. did the 30+ year old clamps give u hell :stupid: . i will prob do the same set up like u have with some thinking here and their. thank god u dont have like a copyright on that stuff LOL.
I absolutly detest those archaic pieces of crap :tapemouth Whoever came up with those did not think of how the weather and time was going to effect the future operation of the built in spring temper of the clamp that is supposed to make it get larger as you loosen the screw but instead stays stuck liftup.sml.gif41616-4.gif how it's set and requires cutting it to get it off 75% of the time and should therefore be taken out and shot in the teeth furax.gif2gunsfiring_v1.gifLOL :rambo: {rant over}
