I am in the process of running my wiring harness and battery leads. Does anyone have a clear photo of where the positive and negative cable run to. I have looked thru the repair manuals but its not clear. I know this is dumb question but i dont want to screw it up. :stupid:
https://www.classiczcars.com/topic/14532-battery-hookup/
The smaller cable comes off the NEG cable,gets screwed to the firewall. There should be a small screw in the firewall that is used for that.
Where on the firewall is that first picture? Also, those bolts look rusty, did you treat them to a de-rusting? I'll put both of those spots on my list.
https://www.classiczcars.com/topic/14532-battery-hookup/#findComment-107315
Well, since the battery is in the picture, I guess it's NEXT TO THE BATTERY!
It is an old bolt and the cad plating is long gone , the entire bolt (along with the terminal) was cleaned up with DeOxiT before winter. The bolt head has since acquired a film of surface rust. Since everything still works normally, I think the DeOxiT is still protecting the threads.
https://www.classiczcars.com/topic/14532-battery-hookup/#findComment-107317
I couldn't tell it was a battery there on the left.
I've been using a copper-based anti-sieze on things like those bolts. Not just because I worked on the formula, and in the lab it showed some interesting electrical properties. Copper anti-sieze worked miracles on exhaust manifiold bolts, even after a few years.
Why not just clear-coat the boltheads? Also, it sound like you give DeOxIt thumbs up?
thx
https://www.classiczcars.com/topic/14532-battery-hookup/#findComment-107380
I
thx
I'm too lazy.
"DeOxiT 100" cleaned up my Wiper Motor connector electrical terminals quickly and easily to bright and shiney metal. When I first looked at them, they appeared so filthy and corroded that I feared they would fall apart in my hands. I am pleased with how it works. It won't add metal back, but it removes the corrosion very well, and seems to protect the connectors from corroding again.
https://www.classiczcars.com/topic/14532-battery-hookup/#findComment-107433
  • Who's Online   1 Member, 0 Anonymous, 1,459 Guests (See full list)
