Site Updates this Weekend ×
The choke does move when Move the lever, it is stiff, but I think it is OK. Could it possibly not be going to the full choke position? maybe. How would I check this?
As far as how long I crank it. Sometimes I had to crank it until the battery died with no success. I have learned now that starter fluid does the trick so I start it that way.
what do you think
https://www.classiczcars.com/topic/14582-is-it-my-weber/#findComment-107871
You need to be sure that the lever moves to full choke. The Weber on my truck starts whenever I need it to. Starting fluid has a way of rattling the bottom end of a cold engine. If you must use that technique, use a small spary bottle with gasoline in it.
https://www.classiczcars.com/topic/14582-is-it-my-weber/#findComment-107880
  • Who's Online   0 Members, 0 Anonymous, 961 Guests (See full list)
